settings for highest quality
hello, just out of curiosity, I would like to know what render outpout settings apply to get an image with the highest quality possible. I rule in 3840 x 2160 very high, it’s already very good but can we do even better by customizing the denoiser for example or something else ?
slide the quality slider all the way to the right… ;p
There is no golden rule but for most cases the Settings quality presets should suffice. Additionally, you can always compensate for using a lower quality preset by utilizing the V-Ray Denoiser.
Keep in mind the V-Ray Denoiser may cause some loss of fine detail in your final production shot. Once the process is complete, you can try out its different presets and manually re-initiate the Denoiser using its “Update” button.
Kind regards,
Peter
