Settings management help after upgrading to 2.6
So what is the method you all use to manage settings? Do I need to save settings for each project and each view? I am having a difficult time figuring out the best way to get the same render for an earlier project once I have changed settings after having worked on intermediate projects. It was quite simple in 2.5 with the presets right at the top. The presets seem not as intuitive in 2.6 how have you all made it work?
Hi. İf you click ''Presets ‘’ ( it is hidden ) just under visual settings , you will notice ‘save and load’ option for your settings.
Hi
I do it like this: Sketchup Pro 2019 setting
When the new project is done in Sketchup
1.) Start the Enscape
2.) if an old settings still exists but you do not love it: I open “Visual Settings”
(Presets - Load Presets ---- Load Presets (default) ------ Click to the top, “Default Settings”)
3.) now I make the new settings in "Visual Settings:
(Rendering, Image, Atmosphere including for example" Skybox "and Capture)
4.) then save under a name. for example: Sene 1
(Presets — Save Presets ---- Save to (default) ---- Scene1)
5.) sometimes I save several scene with different skybox with different brightnesses of the lights, scene “outlines” or
or … etc.
6.) If I would like to have this setting for another PC. I save under:
(Presets - Save Presets ---- Save to Filet) ------for example : Scene1
7.) Attention very important
Sun and Time can only be saved as scenes in "Enscape. “Creative View”.
But as a sketchup scene does not work with sun and time !!
If anyone has any other knowledge, please tell us how you do it
the same questions to me :wink:
if I just would save presets “by default” (so somehow store the presets within the SKP file itself ) I have no idea where they are stored or how to share these.
So I always decide for the option “save to file” and save these files next to the SKP file.
Also, assigning presets to SkUp scenes doesn’t work automatically - should it :?: - And so I load every single scene preset manually.
And a last stupid question from me: Does any Enscape window show me which Enscape preset is currently activated?
Quote from Egie
… I have no idea where they are stored or how to share these.
I don`t know either, but I do not think it’s important because you can put in “Save to Filet” or you can find it in “Load Presets”
At the same time I save some settings under the name for example:
bathroom or kitchen, etc. as a neutral setting in a folder. So I do not have to start all over again
…Also, assigning presets to SkUp scenes doesn’t work automatically
I think so too
… And a last stupid question from me: Does any Enscape window show me which Enscape preset is currently activated?
That would be a wish for version 2.7 or earlier..?
You always have to reload when you start in “Load Presets” I don`t see any other possibility
:slight_smile: thanks a lot for your detailed description :thumbup:
So we proceed quite similar - I note in the SkUp´s scene name itself which preset I have to load here for render,
something like “Scene13 / sn83° / Ensc_005” (btw: “sn” for me means solar-north :wink: because for some reason
of all things the used solar-north angle doesn´t always get scene-stored correctly within SU)
Turn off scene animation in the model settings and it will.
All of this workaround can be avoided of they can just make Enscape save the settings per scene tab. A request I have had for many versions now.
Is there a way to use the “per file” settings globally? (like the pull-down we had before in 2.5) Is the only way to use settings between files is to go through the additional steps of saving a settings file and finding it and loading it into a new file?
Yeah, that’s a lot of steps compared to being able to use global settings in 2.5
thanks for this hint !!! :thumbsup:
.how you do this ? can you share a screen shoot to turn of animation?
