Several bugs. b7.
1) Sometimes, when render seems over the progress bar just doesn’t go to the end.
BTW why “Rendering image…” shows even if render stopped?
2) I tried to check the DOF and then clicked VRay->Options rollout - DOF uncheckes. And not only DOF - any checkbar in Camera rollout/System etc…
Several bugs. b7.
yep you are right on both counts. The progress window isn’t totally done. As far as the VRay Options problem, I never noticed that before. I’ll have to take a look at why that is happening…
edit: Actually I’m only seeing that second problem on the Camera page, none of the other pages seem to be affected
edit2: ok I think the colormapping one does it too…hmm…ok either way, I’ll look into it more
Several bugs. b7.
ok I found the VRayOptions problem and fixed it. Thanks
