1 - single click should be enough to close or open dialogs
2 - double click to open all or close all would be nice
3 - it would be handy to be able to drag and drop colors from one slot to the other
4 - it would be handy to be able to drag the spinners
and a few more
1 - bitmap multiply value: not intuitive. If it has to work the way it is working
2 - I’d make a slider with darker/lighter (with a number between -100 to 100 for example)
3 - I don’t know if it is a good plan to write all info to the commandline, keep it clean. I opt for a separate window like in max.
4 - please…gamma correction color mapping for a starter. Because my monitor has no linear response and since I know that this has always been the cause for too dark and smudgy renderings…
coverting in post, gives banding artifacts when image is only 8bit.
to give an example:
no gamma correction:
gamma 2.2:
several whishes
Gijs,
We will be looking into all of the color mapping types including Gamma Correction.
Corey
