Hi Keymaster,
I’m getting a bug with the Corona material ![]()
Here a render of a simple scene (one cylinder + 1 corona light).
Let me know if you need the max’s file.
yes, post the scene please. ![]()
Hi Rawalanche,
I don’t think so, but to be sure I attached the file max…
corona bug.zip (1.29 MB)
I’ve looked at the file - there is bump - and pretty strong one. If you disable/lower it, it renders OK
The its something I’ll have to investigate
can you post shading normal and dot product shading passes?
Filterig was off for the texture in bump slot. You need to use filtering to get reasonable results with bump mapping
