Hi, after start using the v3 , iv started to have a weird bug, ill try to describe it the best I can:
Everytime I create a shader using the node editor. when there is a “corona shared” material.. it simply renders black on the viewport.
I replicated same error on the scene i’ve atached.
here is an example of what happens:
Im using c4d r18 with corona v3 hotfix 1, under win10.
thanks in advance.
shaderNodeError01.rar (6.22 MB)
Thanks for the file, we’ll take a look.
The scene as sent renders fine in IR and final for me. Are there are a set of steps that would “make it break”? Cheers!
the problem is the viewport. has you can see on the screenshot.
Tested and confirmed. Thanks for the file.
thanks. yeah.. its a bug that you notice if you use node editor. like I started to do.
still no news about this one?
Not at this time, it’s been reported internally and has been sent off for investigation. We will update you once we have some news. Thanks
metopa
9
Internal tracking number: 342697481
