Shadow Alpha
Hello, below is test to get shadow pass but problem is object are also included in alpha of both shadow & matteShadow pass.
And what i want is, only alpha of shadow (i.e No objects & other stuff) like what we do using useBackground shader.
I also tried with VRayMtlWrapper by putting
Alpha contribution= -1, MateSurface=On, Shadow=On & Affect Alpha=On and apply to every object
then i got totally blackout.
What you can do is to add another VRay object properties node to your objects and disable their visibility. Does this work for your case?
Same problem with “vrayObjectProperties”
i tried both
1) primary visibility =Off &
2) matte Surface=On, Alpha contribution= -1, Shadow=On & Affect Alpha=On
Here is my scene File
ShadowPass
The link to the project file seems to be broken - could you upload it again, please. Also what version of V-Ray are you using?
Thank you,
Link is working fine her, just click & u will get option to download from google site
Trial of 2.3 & 3
Here is output of useBackground shader apply to all objects & render with mental ray.
How to get same output using V-ray ??
Thank you for posting examples of the result you want to get.
I made a sample scene setup, which is similar to the one you are using. The final render RGB and alpha channels look like this :
In this scene all objects are set to matte and “No GI on other mattes” is switched off.
Maya file :
ShadowPass
Unfortunately we get this error when try to download the file: Dropbox - Error - Simplify your life
Example.zip (10.4 KB)
Even i m also not able to download ur attach files, getting this error
“Ruchit, you do not have permission to access this page. This could be due to one of several reasons:”.
Actually i see that you are using a trial version of our product, therefore you are not able to download attachments. Per our policy only customers have such forum rights.
I have sent you the download link as a private message here.
