Not sure what to call this but is it possible to achieve this effect without workarounds? I’m guessing not.
Anyone have any experience of this. I’d imagine you’d have to fake it by creating a tree mask and blurring with something like lenscare, then using that to cast a shadow?
In principle,
the larger the Sun Size - the wider and more diffused the emissive source is, the softer and wider the shadow gets. Same occurs in relation between the shadow transmitter (ie. leaf) and its receiver (ie. ground) - the larger the distance between, the more diffused is the signal receiver gets. (see attached and pay attention while observing environment)
From what I can see it’s very dependent on scene settings, leaf geometry/shape, tree distance, Sun Azimuth etc. You can get pretty close tinkering for sometime.
The image Corona_GK posted does seem to show the circle effect, but not as pronounced as the circles you get in reality.
Now I’m curious myself if renderers can simulate that circle shape of the sun in the shadows.
You don’t need anything special to get this in Corona, just plant a tree and lit a sun. This phenomena depends on two things - right distance between the leafs and the ground and many small gaps between the leaves. Usually it’s not hard to get it fulfilled. Basically, it’s the same DOF, it just happens not in a lens, but between the leaves and a ground. Gaps between leaves acts as an aperture and ground is a film, or sensor.
Wait a minute! So you actually added 3D sphere blocker between the sun and the scene? Whoa! I unsuccessfully tried to recreate this phenomena by painting a sun eclipse into HDRI map, but required resolution would be insane, so i dropped my attempt. It never crossed my mind that this can be achieved with 2D sun and 3D moon :] Super cool!
I only meant it for the Sun attribute, specifically for the shape of cast light. That would bring an advantage and added extra value to the engine.
Like there’s a [Textured property for its look/ visual appearance… or did you forgot about the rainbow ;)](https://forum.corona-renderer.com/What is corona sun object ´textured´ ?#msg130767) which is also a deep Fake - basically everything virtual is a “canny fake”
Also, “Physical Sky/Environment” is a whole different matter (which I think you’re implying to).
I did believe that better, highly improved environment system is/was in works or at least planned (along with infinite ground plane, auto shadow & reflection catcher, atmospheric scattering done in a way to also simulate other worlds/planets)… well, maybe it’s in the works or maybe it was just a thought and is now a memory since the R&D department is on hold…
