Are you sure those things are specific to PNG file format? Have you tried with other formats?
I think most of that comes down to “affected by reflections/refractions” options, like you have in V-Ray. We understand that this is highly demanded, and have it logged.
Other than that - like Burning said, please create simple scenes for each of those issues so that we could easily reproduce them. Otherwise it is hard to understand them (or at least we could easily get confused).
Yet another bug with glossiness lower than 1
If you enable reflectivity for the shadowcatcher, and then lower its glossiness, then this “black spot” will appear in alpha of the shadowcatcher. This is definitely a bug, and I will report it*.
The solutions/workarounds are:
Using glossiness 1 for the shadowcatcher
Enabling “shadowcatcher illuminator” option for the light
Bloom and glare not considered in alpha
Currently this is intended. The solution is to:
Add CShading_BloomAndGlare render element and enable bloom and glare in its settings
Add CShading_Beauty render element and disable bloom and glare in its settings
This way you will end up with:
Beauty with bloom and glare
Beauty with no bloom and glare
Bloom and glare on black background
Alpha with no bloom and glare
Then you just have to compose your image and put the CShading_BloomAndGlare on top using the Add operation.
This is probably not very convenient, so it may be improved in the future.
*Issue 1 is actually already reported:
(internal id=173146446)
