Hi, i use sketchup 2014 and Vray 6. When i add shadow catcher material to the scene, it cames with a base material, But when i use sketchup purge unused function, that base material is gone. I can solve the problem by aplying the base material to an invisible surface. Is that the normal behavior of that material?
Hello @kenancakir ,
Currently SketchUp Purge indeed purges some of the V-Ray complex materials, because it does not see them as applied to the object. This happens with Base material of the Shadow Catcher as you have noticed and also some other materials like Blend, MultiMat, Override, etc.
Therefore, we advise using V-Ray purge option instead and avoid purging materials using native SketchUp purge - please take a look at the article.
Also, just to mention - in the newer SketchUp 2026 version materials can be deselected from the purging list.
