Shadow/light falloff for vray ?
it seems that the shadow/light falloff doesn’t work with vray. Is there an alternative, or trick to achieve the same result ?
what i want to achieve is reflection of glass depending of the amount of sunlight it receives.
It’s not perfect since it’s not light reactive as such but if you use towards / away and choose object as the falloff direction, you’ll be able to pick your sun to drive the effect.
