shadow problem
i can’t figure why i am getting this shadow problem.
it started when the shiplap was added (it is modeled in 3d - its not a material or displacement). so, i’m fairly sure in assuming that the shiplap is causing the problem - but i don’t know why its causing the shadow problems or how to fix it.
i am using 1.09.03r… in MAX 6. basic settings for irrad map (-3,-1, clr.4 nrm.5, dist.1, hsubs 60, interp 30) - using direct comp. for secondary bounce.
suggestions please?
thanks,
sean
Untill you get any other sugestions, try upping the irr settings. -3/-1 is kinda low (unless its very high res).
Maybe a little more subdivs too.
Travis
it a settings problem, you really need to crank your settings right up for this type of situation.
Chris Jackson
cj@arcad.co.nz
can you lead me in the right direction as to which settings i need to monkey with?
thanks!
sean
Try upping your hsubs. I was having this prob, i increased it to 100, but I think its different for different situations. Try upping it a little at a time if you have time to mess with tests.
Travis
clr nrm and dist i would put them all at 0.3
