First problem - when I choose ‘For Compositing’ as the Alpha Mode - why does my ShadowCatcher object not render black?
Second problem, is there any way to exlude things to avoid doubling up of shadows etc?
I’ve attached a backplate I need to composite into. I basically need to place a car in the shaded area of the road, and a car into the sunlit area of the road.
I’ve modelled the road, and I’m projecting the backplate onto it using the shadowcatcher material (is this correct).
I setup lighting using a simple sun/sky system to emulate the conditions in the backplate.
I’ve modelled the building that’s casting the shadow across the road as I need to get that same shadow on the car and the reflections from it (this is the problem shadow - I don’t want this shadow on the shadow catcher, just on the car, because well it’s already on the backplate).
You can exclude shadowcathcer plane from light source and it won’t catch drop shadow, but on sun light it wont’ cast drop shadow so i think you may need second shadowcatcher object to cast shadows on the sun
Are you talking about your cars or the ground? If you want the ground to be black in ‘for compositing’ mode, then remove your background image and change the environ/backplate color to black.
*Edit.
ORRRR put your environment shadowcatcher map into a rayswitch map with your img in all the slots except for direct visibility which would be black, and end up like the results below.
