ShadowCatcher lights not visible in alpha
Hey!
Does anyone know how to get the lights included in the alpha with ShadowCatcherMtl, when rendering with alpha mode: For composting ? or is it not supported yet?
There is “shadowcatcher illuminator” option for lights, but I can’t get it visible in alpha.
Yes . look`s like its not incuded in this alpha mode. Is this a bug or is it just not supported yet?
That’s what I did but still it doesn’t seem to work. Direct light is not visible on the shadowcatcher, only shadows and GI.
yes alpha mode"for compositing" not rendering lights that hit the shadowcatcher material.
That is by design. When using the compositing mode, you should place the beauty pass over the background without multiplying it with alpha (assume it has premultipled alpha). The alpha only modulates the background, but it should not modulate the beauty pass to get a correct result. If there was solid alpha below illumination from illuminators, that would make light from one source (scene illuminator) occlude light from other sources (background photo plate) - that is not how light works.
