Hi guys, I’m doing a birdseye view were I have an aerial photo mapped via the coronashadowcatcher material on the terrain.
I’m trying to use extruded splines and the coronadistance map to project new roads/paths onto the terrain, but it’s not working correctly in the beauty pass with the shadowcatcher as the base material. If I use a normal corona material it works great (see white+black screenshot).
Is there something obvious I should enable/disable?
