What you are looking at is not shadow (soft one) its shading. There is two different things here. The shading is the microshadow on the surface of the material if you will, so that could appear soft. Picture this, if you light a sphere with a directional light the shading on it looks soft.
To get soft shadow you need to increase the size of your light, for example if its vray sun, then you need to increase the sun size, or if its an area light increase the UV scale of that light.
