Shadows incorrectly displaying on 3.4
Hi Demian. Yes sure. Can I send it to an email address?
Of course, thanks! I’ll share mine with you via a direct message.
Hi all,
Just sent a DM to Demien, but the crux is that after having the graphical issue above on two separate PC’s in the office the other day…trying it again today, it is fine. Even tested with different files with same file formats, and all seems fine. So very confusing.
Anyway, apologies to all…
](https://forum.enscape3d.com/wcf/index.php?attachment/45169-1-jpg/)
I am still having this issue with the latest enscape and Rhino 6. I am using Radeon 5700XT. I have repoduced this error with both the latest drivers, and 22.10.1 (The latest driver I can revert to on windows 10)
I am having both shadow artefacts (appear as if there are giant objects floating above the model) & blurry shadows.
Right away, this should be resolved in driver version 23.3.1, so could you kindly either acquire and install those: https://www.amd.com/en/support/previous-drivers/graphics/amd-radeon-5700-series/amd-radeon-rx-5700-series/amd-radeon-rx-5700-xt
Also, just to make sure I get it right, you also tried the very latest drivers for your card which is 23.7.2? These can be acquired here: https://www.amd.com/en/support/graphics/amd-radeon-5700-series/amd-radeon-rx-5700-series/amd-radeon-rx-5700-xt
Just in case you haven’t tried these yet, you can do so, otherwise if that doesn’t do the trick let me know - In that case you should be successful using 23.3.1, but if for some reason that also doesn’t help please get back to me.
Thanks Demian,
The 23,3,1 appears to have worked. Noting oddly I had to completely uninstall drivers and then do a clean install of 23.3.1, I believe I was on 23.7.2 prior to this and experiencing issues, however I wont have time to try and reproduce the error at the moment. Need to get these renders done :slight_smile:
