found out that direct light with VRay shadows has much better shadow details then VRay sun (with or without sky, doesnt matter). Why? Both are direct lights.
How did you set up your direct light? The distance of the vraysun is calculated as if it’s infinitely far away (quote Vlado), a direct light not really, if you would place your light very far away it would produce similar results I suppose. But I might be wrong.
What @Vizioen said. I don’t think a direct (and accurate) comparison will ever be adequate, since the shadow softness is controlled by different means (Sun size / Area Shadows UVW). Eyeballing it, I’m getting similar results when the Direct Light is far enough and has big enough Area shadows.
Yes. But I set the sizes to be pretty equal on both light shadows. But direct light has much more details.
Can you attach the scene so we can take a look?
It doesnt matter. I compared two lights with the same size. Details are different.
But you compared the vraysun and a directional light? Right?
If you think you should raise a bug report, feel free to do so.
I dont know. I just like the details in direct light which I cant produce with sun light (which is direct too). With direct light there are really nice circles in the shadows.
I’m not sure there is much you can do: the sun is simulated really far away, so it’s with near-parallel rays, and the softening will happen chiefly in one direction.
With an area light, even with the same screen size, you will get broader ray angles to the subject, and the blurring will be more circular.
Perhaps You may use a directional light in place of the sun, as the sky map allows for it (although it doesn’t carry the clouds’ bits yet.)?
He could always align/link the light to the sun, disable the VraySun diffuse and set to invisible and put a VraySky in a dome light set to affect only specular/reflection and disable shadows. That way he can have both, I guess? Save as a template and you’re good to go.
I don’t think in fact he can do anything: if he switched the sun for a direct light, the shadowing would still not be the same, still dependent on an area shape, which however would then be located where the directional light is.
So, you still wouldn’t get the near=parallel rays, and the directional blur of the sun.
To sum it up:
directional with area shadows (aligned with the sun, crucially *somewhere* in 3d space where it can be edited):
Yeah I’m aware he won’t get the same shadowing, but apparently that’s what he wanted
So if he wants to replace the sun with a directional because he likes the shadows more, than to get clouds and proper reflection from the sky he can work with the above workflow or am I missing something? It’s monday after all.
Yes, indeed he’d be able to work obtaining different results from the sun’s use!
It’s Monday indeed, bear with me! ![]()
Um…what has Monday got to do with anything? Surely Lele, your cave won’t permit light’s ingress, much as that of many others ![]()
Yes, I just like the shadows/details. I like the circle effects which is very well detailed in every situation with directional light. With sun light it is not as good and easy. And I never get those details.
I have a scene with sky with directional and sun so I can switch between them. It looks ok and very similar. The problem is directional light has a problem with translucency leaves so I cant use it if I see the trees.
Have you tried decreasing the sun’s size below 1 to see what effect it has?
Yes. It doesnt help size is the same, only details are different.
