Hello!!! in multipass, the shadow pass seems to be a sort of “color negative”, not the black and white file I was accustumed withj C4d… How do you use it???
Set to blending to ‘subtract’ in PS.
Yep, the pass is the energy subtracted by shadows, so you just Subtract it from a result with no shadows to add them in (or I guess even with a pass that already has shadows, if you want to just keep making them darker). You could use Linear Add over a regular beauty with shadows to reduce shadow darkness but you couldn’t increase shadow darkness that way.
thank you!!!
