hi everyone,
i need some help about shadows, the render is working perfec but i have a problem with the color of the exterior shadows, they take a blue color and i want them in grey…what can i do???
thanks
hi everyone,
thanks
Re: shadows
Please post a screenshot using Photobucket or Imageshack. It’s pretty much impossible to comment without a screenshot.
Re: shadows
Your shadows are most likely a blue color becauese you are using a physical sky and sun. Try setting the environment to just a white color or an HDRI of something other than a sky. If you change your environment make sure you also change the background too.
Re: shadows
You can also try using the white balance in the camera options, and making it a blue color. This will make the shadows more of a white-orange color. Play around with this see what effects it renders.
Justin
Re: shadows
You can adjust the Turbidity control of the sky itself to decrease the “blueish” appearance. Check the link below for examples
