Shape Map not working with bump and displacement..
Am I doing something wrong or the Shape Map is not working with bump and displacement..
Shape Map is the one that use spline shape and rasterizes it.
It works with Arnold.
It works with Corona too, but you need to set mono channel output to RGB intensity, by default it is set to alpha. Alternatively you can leave mono channel to alpha, but set alpha source to RGB intensity, which is essentially the same as the first method.
Nice!
Thanks a lot!
You’re welcome!
