what file I have to copy to share custom assets?
Is it Only sharing .assetpkg files enough? Everything is included.
Thanks,
Alejandro
Thanks,
Alejandro
Hi Alejandro - Someone else can provide more detail for custom asset sharing. It can certainly be tricky across shared projects. We’ve start sharing workflow with customers / endusers that involves nesting OBJ files into Revit families. This avoids the need to share custom asset paths, less complicated, highly detailed, and allows changes to the nested OBJ file that doesn’t effect other projects. Hope this helps.
https://www.linkedin.com/pulse/sketchup-revit-enscape-ftw-phil-read
Each custom asset has two components, an ‘asset package’ (.assetpkg) and the ‘generated asset’ itself, which consists of a folder that holds a number of subfolders and files.
The asset packages will be saved in your ‘asset projects’ folder and the generated assets in the ‘assets’ folder. The folders are customizable so you need to check your settings to find out where they are being saved on your machine.
If you want to share the asset you have 3 options:
share only the ‘generated asset’ (for example by making a zip file of the folder holding all the generated files). This will allow the user to paste that folder into their ‘assets’ folder and it will appear in their library, but they will not have an option to customize it (change the category, tweak the materials, modify the name…)
share the ‘asset project’. Now the user will have the option to tweak the asset, but it will not immediately appear in their asset library. They will first need to open the asset project in the asset editor, and generate the asset from the project.
share both the ‘generated asset’ and the ‘asset project’. Here the user gets a customizable asset but can immediately start using it without having to generate the asset first. The downside here is that you have to make sure the user drops both the ‘generated asset’ and the ‘asset project’ in the correct folders.
Since you have a good understanding of how the asset folders work, maybe you can help me fix my library.
When I first set it up like 7 or 8 years ago, I didn’t understand what Enscape was asking for and somehow nested my working directory inside of the actual assets directory. Then someone else came along and put the working directory inside a single asset folder.
So I’m trying to consolidate the assetpkg files, but I basically broke them and they don’t show in my Asset Library anymore.
I’m assuming there’s something in the json inside the assetpkg that is confusing the file with the old directory or something?
So I 100% have been doing the thing from this screenshot for years somehow.
EDIT: They are magically showing up in the Custom Asset Editor, but not the Asset Library. I assume it’s just lagging and will refresh itself eventually.
I actually had a similar issue an hour before a presentation and the assets were found 5 min before we started. In that instance it took 10-15 minutes for the correctly placed asset folders to show the assets inside Enscape.
