Shared folder - on the server
Usually I work on Mac, and In setup all my scene with objects and materials from Chaos Cosmos. But to do the final render I use Windows Machine because the Hardware is stronger.
The problem is to relink the assets from Chaos, because they are missing on Windows machine. There is away to relink them all at the same time, and not one by one? I can relink objects at the same time works fone, but the material textures I have to relink one by one.
To resolve the issue I was thinking to share a folder on the server so the assents ar always in one place. But I am not sure if with this option the render time raise.
Another solution is to save the “projects with assets” and open on another machine, which I don’t know if that is possible whit Chaos assets…
Many thanks
Hello @francisco_fernandes ,
Apologies for the delayed reply.
On your Windows machine, you can simply go to V-Ray Menu> Chaos Cosmos> Download Cosmos Assets, which will download and relink all missing assets in the scene. You don’t need to relink each asset one by one.
I hope this is of help.
Thanks Aleksandar for your reply.
You can also setup the windows machine with Vray as Standalone and have it render from your mac using Distributed Rendering.
It also allows for rendering with both machines or only the windows one.
You can find more info here:
