Hi folks, I’ve had a search for this but not come up with anything so
can some one tell me.
Is it possible to keep your .ini file on a network drive so that when i change or add map paths i don’t have to update all the render nodes? This would be very useful.
Cheers
just copy the same ini file to all of you servers…
you can write a batch file that will do it for you.
One is supposed to be able to “nest” ini files inside each other. More like referencing. Each local ini file has a path to the real one on the network, but to be honest, I have still to get it to work. There is some info about this in the max help as far as i can remember.
if anyone has solved the remote ini issue, please speak up!
…been wanting to do this for a long time, but i can only manage to pull it off with the plugin.ini
