Shared shader hinders attributes display
Not a big deal but I noticed that in some cases the shared shaders are seen by C4D and prevents the Attribute Manager to display properties with shaders of the same type :
Here I was trying to modify a setting on multiple Normal Map shaders at once, only to fail because of the shared shader.
I was unable to reproduce this issue on my end.
Could you please raise a support ticket with us so that we can investigate it properly?
Please submit it here: https://support.chaos.com/hc/en-us/requests/new
When submitting the ticket, kindly:
  • Attach the scene file where the issue occurs.
  • Clearly describe the exact steps to reproduce the problem on our side.
  • Mention the Cinema 4D version and Corona version you are using.
