we’re working with Rebus Renderfarm for almost 2 years now and we’re pretty happy.
Support is great, rendertimes are quick and the plugin is well made.
Unfortunately they are not able to render materials set up with shared shaders.
Now I wanted to ask if any of you (or the devs) could tell me if this is a known technical limitation for farms in general and is simply not possible or if there might be another farm that can work with Corona’s shared shaders?
Hi Flo,
Maybe it’s too late for an answer but maybe it will be usefull for other people.
I had exactly the same problem I think.
The error message from RebusFarm Quickcheck was : Error Pluginshader corona shared (1040749) are not supported
I didn’t have this problem before Corona 6 (c4d).
So after hours of debugging my scene in all the way possible, I found what’s going wrong and its easy to solve : some materials from Maxtree Collection (and in your case, maybe from other model collection or selfmade materials) contains Shared Properties, you just have to rebuild your material by replacing original texture in place of all textures named with “texturename(shared)” or “texturename(bitmap)”.
To be more accurate, in my case the problem seems to only exist with MAXTREE PlantModel vol016 (I have many others collection and at this point, I do not have Error message with it).
Maybe it’s not the solution you expected but in case of rush, you can do this to be able to render with rebus…
Best regards.
Hello
I had this problem too. But now, after I have spend hours to resolve this problem, I found a way to avoid this… Open the corona node material window, under the tool menu there is an option to save without shared shaders! And it save a exact copy of the work but with out any shared shader (it automatically duplicate the necessary shaders…)
Hi friends,
I still get this pluginshader error on Rebusfarm despite doing all the things you mentioned! Am I missing something? I cannot use Rebusfarm practically…
the “save without shared shaders” is a legacy feature that we added mostly for internal use (when handling backwards compatibility), and is probably out-of-date. (We already wrote this to devs some while ago).
Unfortunately, the only workaround right now is to duplicate all shaders which are shared - those are shaders, which in the node material editor have several lines coming out of their output. I know it is tedious to do if you have a multitude of materials, but it is unfortunately the only solution at this moment.
as WorkFlow stated, Rebus developers have blocked this feature internally until they figure out to fix an issue on their end. It is unfortunately out of our hands, so the only thing we can offer is a workaround, as I have stated before.
