do any of You guys know how to project material on shadowcather for composition in 360 spherical panorama? Frontal gives no results. Using projector in “shadow” also.
OK. Solved. Request to administrator to delete post.
Do you mind first sharing how exactly did you do it? We will then move it to Resolved so that future users can find help in this thread ![]()
Thanks,
Jan
Yes. Of Course. Solution was in the shadow catcher. Just didn’t knew this option.
Had to change Matte/Shadow option from “backplate” to “environment” and then Environment slot activates. Then simply drag and drop my material with photo form “environment” in Render settings->Scene environment to rayswitcher “environment” slot. And it works fine.
Another problem is that such shadowcatcher render is distorted like Environment. I had no solution for that. I was looking rof solution of distorted environment some time ago but only solution was to replace enviro in postproduciot.
Do somebody know if it was fixed?
My version of corona:
Build timestamp: Oct 8 2020 02:03:04
Version: 6 hotfix 1
Hi, are you able to share your scene with us to investigate? We have a private uploader that only our staff can access. If so, here’s the link:
Scene i spropably uploaded.
Sity from the link didn’t give my respond such as " uploading sucessfully" and all turn white witch “413 Request Entity Too Large”. If files did’nt uploaded then please give me info. Scene was 600 zip.
Hi, I do not see your file. At the bottom of the uploader page, you will see a dropbox link. This can be used instead as your file is too large for our regular uploader. Once uploaded, please let us know the file name.
Thanks!
File Uploaded by Dropbox. File name: Scene_CORONA.zip
Thanks!
HI,
Can you also tell me if you’re a macOS or Win user and what version you’re running? Thanks!
WIN 10 PRO64 bit.
Version 20HC
Gear
AMD Ryzen Threadripper 3970X
32-Core Processor 3.69 GHz
RAM 128 GB
NVIDIA GeForce RTX 3060 Ti
Thanks for the info. Since we just released a new version of the V7 daily build, could you please test it and let me know if it resolves your issue?
now it works perfect.
Best support ever. And You made it before final render for the client. Thanks.
Thanks for letting us know! Glad it helped ![]()
