Shiny animated textures.
Hi all,
In animation, I often use textures animated people like marlins.
It often happens that parts of these textures don’t well render.
It happens even in “Single Frame” renders.
The alpha textures are OK.
And some images of the sequence are well rendered.
Thanks for your help.
Arno
Any coplanar faces in those objects ?
nikki Candelero
Nop…
Single face with Material on Back Side checked… The same bad result when I flip the plane.
Arno
You can try rotating the planes slightly (in case they are perfectly aligned to a coordinate plane) and see if it fixes it.
