Shiny volumes
I was wondering if its possible to create shiny volumes for like foam or whitewater, so it has some specular highlights. I can create like a custom normal based off the gradient for the volume with the vdb analysis node.
Hi Tarin,
Good to see you here :slight_smile: Shiny, i.e. specular component for volumes - not supported by the volume shader yet, unfortunately. You could surface your whitewater and use a layered scattervol/vraymtl shader where the first one provides the volume, and the second one - the reflection, you’ll have to make it transparent by refraction = 1, refractive IOR = 1, unlock separate reflection IOR and add in the reflection. That’s a surface and not a volume, but works for us with foam, and only misty parts get rendered as volume.
When I VDB mesh the whitewater for foam, the scattervolume turns black. I think it’s because its more picky about having a perfect mesh since its using some more bruteforce solution to calculating scattering. Any tips on fixing the mesh so it works with the vray scatter volume shader?
Using particlefluid surface operator directly on the particles seems to create a good mesh and it works now. Vs what i was doing before using the particles to create a volume and then converting the volume to a mesh with “Convert VDB”. Thanks! Hristo
Black maybe means that the mesh is not closed? Which might happen if you’re using the fluidsurface HDA which does a bunch of operations, but with the basic vdb from particles/convert vdb to mesh you should always be getting a closed surface and that should work well with the scattervol shader.
Funny enough if I remember correctly, it was possible to render volumes (sdf vdbs) in maya vray as a surface (with the volume grid)… wondering how difficult it would be to port over.
Oh really? I haven’t heard of vray rendering these, that would be great to have :slight_smile:
I would have to doublecheck, but I’m pretty sure. It might also be only possible if you have phoenix FD (in Maya). I believe they initially used that (or maybe even still do) to render fluid bodies.
Or it does some iso surfacing - I’ll look up
ok, so I checked in maya and it works with the standard volume grid - just put a sdf vdb in, set to houdini fluid preset and apply any surface shaders. I think initially it meshes the volume (on import for the viewport and again on rendertime). I beliefe if you set the rendermode to isosurface it renders the volume directly.
Could be that it’s Maya and not V-Ray that’s meshing it?
unlikely. don‘t think there is any function in maya that meshes vdbs (except for bifrost maybe, but this worked before bifrost was a thing, its also not loaded here)
