Ship in Ocean
Rather impressed with Ivaylo Katev’s Ship in Ocean simulation. Am I correct in understanding that achieving similar results cannot be done with the current public Phoenix FD demo v2.10.10?
Regards,
yes, this is made by nightly build. if you try to simulate it with the official 2.11 the splash/foam will have worse behavior.
if you need similar simulation, you can ask for nightly build access, the ship scene is included in the samples.
Ivaylo, would it be possible for you to post the settings you used for your “ship in ocean” simulation (screenhots or whatever)? I know the scene is included in the PhoenixFD for Max, but for us Maya users it’s not really useful :wink:
of course
the scene scale is 20 cm
there are a box placed between the propelers, it is made to be a source directed backward, to produce the effect of the water pushed by the propelers.
the ship speed is 50 km/h
arghhh, I don’t have permission to see attachments :slight_smile: could you send by mail… pleeeeese :wink:
I have to buy PhoenixFD, LOL !
Email our support guys to support@chaosgroup.com - they will sort this out.
great, I have access now ! Thanks a lot :slight_smile:
Ivaylo, Have you ever tried to move your ship in ocean scene to maya ?
well, we have to do this, because this is one of the samples.
Symmetric conservation mode…
Havent try that ever with waters.
don’t use symmetric + FT :slight_smile:
OK, but it apparently have some benefits to smooth one?
yes, the symmetry is important :slight_smile:
what is the difference between symmetric and smooth, because I was wondering also what I should use ? I know you used symmetric in your boat example…
I think these things should be point out more efficiently, cause now users just dont know when and why to change any default parameters and features.
I mean there could be many different small examples with gif sequence to explain in documentation what each features do and why. I hope you get my point.
for example if you have a boat and see it from the top, it’s very easy to get different left and right wake parts when smooth is used.
in general. the smooth conservation is an alternative for the cases when the symmetric one leads to instability or artifacts. for example the liquid simulations with symmetric and FT are not stable.
Ok, thanks Ivo, very good to know.
I have generally always left conservation to smooth, cause I havent got any proof of cases where symmetry (excluding nuke, which is a good example) or slow motion could be better.
I think I found the “secret” of your ship in the ocean simulation. I was always concentrating on the grid, waves, wakes and the foam. But actually what makes the difference in your settings is the splash !
It makes much more foam and everything looks better. I could find out thanks to resimulation which is really much quicker to test when you simulated already the liquid.
So, when you need foam, you should splash a lot ! Stupid me :slight_smile:
yes, the setup uses “foam on hit” option of the splash, this means more splash=more foam.
I’m back to this with FD 3.0 Beta. Was there ever a Maya tutorial scene made ? For now, I’m trying with my old scene.
I’m hoping to get a nice ship in ocean made in the next days.
