shop in dubai
after a long time, some new images from the last project we made.
best regards
themaxxer
Great images…!
Very nice! Great lighting.
Only crit is I can’t really tell what’s happening on the brick(?) wall in the second to last image. May be just a resolution issue though. Also, the empty display cases but understandable depending on your timeframe, it just stands out in the last image because it’s an empty case right in the foreground.
very-very nice!
and nice mood also!
congrats! :wink:
the brick wall is correct. it’s a kind of natural stone that’s shifted. and the timeframe was really short. the modelling and rendering was done in 2 days.
best regards
themaxxer
Fantastic images. They look absolutely amazing. Keep up the great work.
Impressive! One question, LWF workflow?
wow, if the people weren’t there they could pass for photos! But I really like the white people too, gives it a bit of an artistic feel. Were they modelled by yourself or purchased?
I SECOND THAT - NICE IMAGES - PHOT REAL - ESPECIALLY FOR TWO DAYS WORK..
I LOVE THE WHITE PEOPLE! DID YOU MAKE THEM? BUY THEM?
Great Renderings! :smile:
Amazing!
no, I don’t use LWF, its to complicated for me. :slight_smile:
it’s very basic, vraycam, blue environment color and a lot of lights… also photometric (ies). the trick is the balance between light, colors and the cam. I used reinhard at 0.3 burn value. to get more contrast I used the old brightness and contrast effect from max. :slight_smile: it could also be made in post, but… I usually save the images as tif 8 bit.
best regards
themaxxer
themaxxer,
How did you do your glass boxes? I know there are a few different methods out there…just wondering which one you used.
well, just make a box, delete the bottom poly and apply a shell modifier. voilà. :slight_smile: very simple.
best regards
themaxxer
very nice maxxer ! :slight_smile:
and i guess after you shelled it, you adjusted the vertex to align at each other? manually?
I was wondering about the material too…you must have some coloured fog going on right?
I love these images…
the glass material is very simple. a black difuse color, 255 reflection with 1.6 fresnel, 230 refraction ior 1.6 (default) fog color like the green in the images at multiplier 0.2.
best regards
themaxxer
