My shots . Im try make SSS surface material in corona c4d but i cant . Who can help , pls?
Cool stuff! I like the composition in the first picture, really great dude !
EDIT:
OOOps, sorry, I missed the “Cinema 4D” part. I wondered why you have any problems with SSS.
forget the below…
It’s very easy to setup SSS in corona.
https://coronarenderer.freshdesk.com/support/solutions/articles/5000534910-how-to-use-subsurface-scattering-volumetric-absorption-and-scattering-
“To enable scattering effects, you need to allow light rays to pass through object’s surface first. To do this, you can use refraction, translucency or opacity controls. Scattering materials should only be applied to solid, capped (watertight) objects. For objects with no thickness, use translucency instead.”
… and then use Absorption and Scattering controls…
Piotr
