should i upgrade my computer hardware
my model is 38MB, i found it’s really slow when update material preview in VRay. my computer using Windows XP with hardware below:
Intel(R) Core™2 Quad CPU
Q6600 @ 2.40 GHz
2.40 GHz 2.99 GB of RAM
should i upgrade hardware and operate system? what’s the regular basic hardware requirment for properly running VRay in Sketchup?
thanks so much!!!
Re: should i upgrade my computer hardware
Nothing wrong with that spec, what size bitmaps are you using for your textures?
i have a farely big map with 8368 x 8701 pixels
That’s your culprit, that is very large for a material bitmap. Those sort of dimensions are common for backgrounds and HDRIs, but I’ve never needed to use anything bigger than 4000 x 4000 px for textures and that was for extreme close-ups. Where did you get a texture bitmap that size from?
i required the image from manufacture. it’s for a waving ceiling. my problem is the UV map ruby script doesn’t work for curved shape, so i edit a huge map in Photoshop instead.
