Show GPU stats in VFB
I cant find the setting in Maya. Where is it hidden?
It is located in the Stats tab (top right of the VFB2, next to the Layers tab). Note that there is an issue with GPU stats in Maya exclusively (nothing shows up), which our developers are currently fixing. I’ll notify you when the fix is implemented in the stable builds.
Thanks for the info. GPU stats are super important.
You have to balance the resources much better than with CPU.
