Am I doing something wrong or is something not quite working.
In max 2012 I just can’t get show material in viewport working for vray materials …
standard materials work fine …
Is this a limitation for 1.5 with 2012 or am I missing a settings/toggle/button somewhere ?
It will only work in DirectX/OpenGL modes. V-Ray 1.5 does not support the Nitrous viewports; however V-Ray 2.0 does (we had to do quite a lot of work on that too).
Some confusion about vray 1.5 not supporting Nitrous. As I understand it Nitrous is used to obtain a “close to render look” in the viewport. When you say 1.5 doesn’t support Nitrous, at what level? I have Nitrous enabled and I am able to see vray materials in the viewport with 3ds max default lights, vray plane and vray sphere lights. With vray dome and vray sun/sky the materials show up as black in the viewport. any help would be greatly appreciated.
