Show/render some lines
Possibility to render some lines , using an object color or material
  • currently the outlines function shows all edges
  • to bypass this, currently i’m “piping” all curves and applying a material to the pipe
Submitted on AHA Ideas by Frederico Francisco (ENSCAPE-I-1622).
Thanks for submitting your idea! But I’m afraid we are not entirely sure if we understood it correctly. Is it the same as this one (https://chaosenscape.ideas.aha.io/ideas/ENSCAPE-I-1509) ? If not, what’s the difference?
Submitted on AHA Ideas.
For example rendering a mountain with topography lines (if terrain is build in 3D sometimes having the topography lines helps to understand the topography). Building those lines in 3D (ex. piping) will mostly crash the PC)
Submitted on AHA Ideas by Frederico Francisco.
Thank you for the example. Currently we are exploring the possibility to render topography lines. Another user has added the idea to the Portal already therefore I will merge them.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
