Show Spectator (Camera) Height in Enscape Viewer in Walk Mode.
For some weird reason, the spectator (camera) height is in device setting, instead of visual setting. When creating scenes with Enscape viewer, it is not possible to ensure the specific camera height per each view.
Alternatively, it will be very convenient if Enscape viewer shows where the camera is in Z axis. Even Sketchup provides a way to set the view at a specific height.
Thank you @L.S , I will forward that inquiry of yours - This is something which has not been requested very often before. Perhaps it may also be a bit confusing when using Walk Mode only and the height of the camera would be different in each view. As if the spectator would be a different person with every switch. Assuming that you would want to still walk, otherwise, if it should be static anyway we would simply recommend making use of Fly Mode to save views - May I ask why this is not sufficient for you? Just so I can add it as further Feedback to the inquiry I’ll file.
@Demian_Gutberlet
Think of it as camera, please.
@Demian_Gutberlet
It’s absurd Enscape doesn’t provide a way to specify camera height. The current method doesn’t count as it can’t be changed per scene, and it’s not even in the same visual setting.
I realize that this may be a frustrating endeavor indeed to some extend since views cannot be directly updated currently (Besides via the Visual Settings) - I’ll also forward your further input to PM, I appreciate it and you have my understanding.
