Show texture in viewport 2024 problem
Show texture in viewport button in slate in max 2024 with VRay 6.1 didnt do anything. No texture shows up in the viewport. Dont know if this is max related or vray. But it is a huge problem cause I cant properly place my textures. Is there anything I can do?
Thank you.
I believe I read a post on the AD forum yesterday and they said it’s a bug.
It’s missing the dropdown option too.
I can’t find it again though.
It still works if you right click the material and the option is there.
EDIT: And typically after posting I found it again :stuck_out_tongue: https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-2024-new-slate-material-editor-bug/td-p/11890081
Aaaaa, great, thank you.
I got one more - triangles on preview in slate sometimes doesnt show up even material is applied on object. Max 2022 and 2023 was fine, 2024 works weird on that.
Ah yes…maybe plenty more to find…you’d think they’d check these rather obvious things :stuck_out_tongue:
Yes, probably. But i would expect that they find those before release.
Well, you say ‘they’ but maybe it’s now just one person, at the weekends, if they’ve not got anything else going on :stuck_out_tongue:
