Show VFB BUG
Finally had a chance to install 1.7. After exploring the new features
and using Corona Interactive, I closed the Corona Interactive window
and pressed the “Show VFB” button (under the Scene tab) but
nothing happened, no VFB window. I switched to the Default Scanline
Renderer and then reset back to Corona, the “Show VFB” would
function properly and launch the VFB window.
I remember also having this reoccurring issue with Corona 1.6.
Could you guys reproduce and investigate this persistent bug?
I’m running:
3ds Max 2016 SP3
Corona 1.7
Windows 7 Prof. 64bit SP1
Nvidia 980Ti Driver Ver. 378.49
I have Vray 3.60.03 also installed but it had not been set as the
renderer at anytime since today’s machine power on.
Lawrence.
-started IR from the scene tab
-closed the IR window
-pressed show vfb in scene tab
Everything working fine here. Max 2018, Win10, Corona Renderer 1.7.
I think OP is talking about interactive in viewport. This is known bug and has nothing to do with one’s hardware or installed programs.
I found the same issue. it’s doesn’t appear.
Also the lock view mode in the in the main render setting box , has never worked for me.
Would love to see that fixed.
Thanks.
phil
Hm, never had issue with lock view and i use it constantly. There’s one thing though, in 3ds max 2016 it has to be toggled in render setup window and not in native VFB, otherwise it won’t work, but that is Autodesk’s bug, not Corona’s. And i wouldn’t be surprised if in later versions it would become more buggy instead of being fixed…
Fixed
