I imported a scene which was originally in the Vray renderer engine. I ran corona converter, relinked all the bitmaps. But it shows warnings and doesn’t render the imported objects. I have attached screenshots to depict my problem.
Also, it renders those particular objects black when I use vray renderer.
Someone, please help me out. Thank you.
The VrayVRMat material is not supported by Corona (the red area in the render specifies the type of the material that can’t be rendered), and can’t be converted (as there is no equivalent). You will simply have to repaint those objects manually with a compatible material.
Thanks @TomG
It has been really bugging me for a few days. Finally, I have an answer!
Most welcome, always feel free to ask, someone here will be able to help!
