sim engine wars..
Just want to thank you again for keeping the original conservation/material-xfer options built into PFD for liquid simming. Seems I can still open an older PFD scene and sim using Multi-pass which still gets a lot of use here. Hopefully it’ll be kept in for future releases. Thank you!
Hey, hope it saved you some time :slight_smile: We have developed an internal system for preserving compatibility with older versions and most of the time it can be applied. Unfortunately sometimes the most obvious things cannot be kept that easily or vice versa, but usually it works :slight_smile:
Awesome - it sure did. Glad you have that system in place. It’s working great! Thank you!
