Similar to Corona, add an object replacement tool
Corona replacement tool in V-Ray. Tool for replacing objects in the scene, very handy.
Submitted on AHA Ideas (VRAYMAX-I-170).
Can you give a specific example? What exactly would you like to replace and why?
Submitted on AHA Ideas.
Just Corona rteplacement tool. It is a tool to replace object/objects with other object or objects in the scene.It could be handy for a lot of situation. It is probably not related to Corona render, just came with instalation. So you can probably add to VRay instalation too.
Max has something that could do this already.
https://www.youtube.com/shorts/7XzpaLHigV4
In my opinion, it is a lot more flexible as a modifier. You can check it as well.
Substitute modifier is a lot different.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
