Since there are TX files appearing in the CORONA environment, I decided to build a simple GUI for handling conversion to/from TX files using oiiotool. The files themselves are no magic. If we change the extension to Tif, Photoshop will handle them. However, we will lose the Mipmaps that are embedded in this format by default. I tested the GUI below on OpenImageIO 2.2 and 2.5.8.
Functionality - drag and drop, conversion of any (I think) files to TX format, checking statistics for TX files, conversion of TX files to Tif format.
Installation - requires Python 3 (tested on 3.12) and pyside6. The sGUI_oiiotool.py file should be copied to the folder where oiiotool.exe and iinfo.exe are located. It works for me.
Maybe someone will find it useful ![]()
https://github.com/conceptfab/Simple-GUI-for-oiiotool
I did a test on the scene with different texture files
and textures in tx format.
jpg, png, tif, exr tx
tex folder 950 MB 1900 MB
textures 346 files 346 files
ram usage ~21 GB ~21 GB
Preparing scene 100 sec 19 sec
render time 10:37 min 9:02 min
pass limit 40 40
edit:
I’ve added the ability to run the script directly from within C4D. You just need to write a simple script:
import c4d
import subprocess
def main():
# Path to the external Python script
external_script_path = ‘path_to_the_OpenImageIO_files_and_script\sGUI_oiiotool.py’
# Running the external script in the background
subprocess.Popen(['python', external_script_path], shell=True)
if name==‘main’:
main()
