simple interior
hi,
It is a scene to test lightcache in vray 1.46.13 and I have to say it is clean and fast.
Only a direct light, skylight and one photometric light. No vraylight on the windows. A little post process in photoshop.
bye
Really nice work! There’s just something about the sofa that doesn’t look right - perhaps a bit more texture to it would help, and have the cushions a slightly different tone. The lighting is spot on.
Nice rendering,
(nice flowers on the table too :wink:)
one thing is wrong: the plant on top sticks through the ceiling
since I am currently working on a scene with similar approach (only skylight and direct light) can you mention your color mapping settings and light colors / multipliers?
NICE and SMOOTH… :smile:
Like the atmosphere… CONGRATS…
nice work! Can the TV be beveled a little bit?
thanx to everybody,
- yes, the sofa would be better with a texture (the same for the carpet) but the designer loves everything with clearly colors.
- yes there is an error with the plant near the celing :smile:
- the vase and some other furniture come from evermotion, ultra3d and (maybe) e-interiors
- the model is in mm (I tried in cm and the light result is a bit different…I don’t know why)
no glass on the windows
direct light (RGB= 255,237,197) with multiplier=2
sky (RGB= 236,240,255) with multiplier=1,6
Primary bounce 1
Secondary bounce 0,9
IR for primay bounce with preset High
HSph 50
Interpolation 20
Light cache for secondary bounce
Subdivision 1000
Sample 0,01
Scale screen
Pre-filter 60
Filter None
Glossy with light cache and number of passes 5
Color mapping Exponential (dark=7, bright=7)
These values probably aren’t the best to lighten the scene…so keep it like an example. If you have time, optimize the settings.
bye
fabrizio
I was going to ask how you got such depth and contrast out of LC, but I see that you used IR+LC. Makes sense now. :slight_smile:
I’d love the speed of LC with the look of IR. Is that too much to ask? :slight_smile:
What was render time?
I don’t remember time but it is faster then 1.09 with IR+QMC
bye
Why did you choose for such a high prefilter for lightcache?
wouter
It was my first try with lightcache. Probably there are settins that aren’t right :?
bye
Hi Fabrizio,
Very nice work!
Just 2 things i don’t like too much. First one is the light in the corner, could be more smooth , second is that curtains are a little bit too much lighted .
It is my taste of course.
Cheers,
Marco
hi tutanmark
I agree with you; the curtain is very bright…but i had few time to optimize light settings and materials. For example in this scene the floor seems plastic and not wood :smile: .
Moreover to speed up settings I removed glass and curtain.
These images were for a little work with a very little payment… :lol:
bye
