simple texture mapping tutorial
guys got a little tut for ya all.
hope this help in a simple way.. :wink:
1. Enable Hidden Geometry.
2. Upload the texture to your scene.
>select texture>edit>use image>browse
3. Right click a single field in the object>texture>check “projected”
4. Select the “projected” field and reapply it in the whole object.
5. Edit texture to appropriate size.
That’s it!..your texture mapping problem is solved! :wink:
/migz
Re: simple texture mapping tutorial
you trick me, migz!
just kidding.. I can see from your print screen, that u use a “green” icon program…me to
so if “they” let you in, well my friend your problems with any kind of resources for CG WILL BE HISTORY!!
Check this, and pray that the registration section is still open:
this is simple, because you use the sketchup PRO…i cant do it!!!
:cry:
R u kiddin me migz…
If there’s just a little time that i’ve got, how can i projected it one by one.
Is there any solution that we can do in vray material to input the pattern?
Regards,
Nick
nick,
1. u only change a single “triangular entity” to “projected”
2. click it using the bucket to obtain its “projected” property
3. ctrl-a to select all then reapply the properties youve just obtained.
that’s it. :wink:
good luck!
Thanks migz! I’m using right now your tutorial to make kind of towel>
Very usefully!
glad to help my friend, :wink:
hope nick got it too.. :frowning:
