I came across a simplified .ocio file on the forum recently. I can’t find that thread. Could anyone link it up here?
thanks in advance,
Karol
thanks in advance,
Karol
Here you go ![]()
https://drive.google.com/file/d/1TTfQSk1glnCpIziDYi36lWA\_zlbhtbuv/view?usp=sharing
Let me know if there are any missing conversions you are interested in, and I will add them
Best,
Muhammed
Thanks a lot Muhammed! ![]()
+ should I keep my viewport in srgb ACES or RAW ACES?
Hey Karol, Viewport should be ACES sRGB(like the frame buffer and material viewer), and the material viewer seems to be fine to me. it is a bit darker compared to usual because of the contrast the ACES sRGB Output Transform uses
Can you show me the settings for the file node for this material, to make sure the setup is all correct?
On another note, I’m updating the ACES docs now. I will ping you when this is ready, it should answer most of the questions on the workflow
Best,
Muhammed
I believe that person has the same issue, I’ve read through it but I feel kinda lost in all of it.
Hey Karol and happy new year ![]()
I’m making a video on ACES setup in Maya, I will ping you when it is live. there is also an updated to documentation soon about this
About color picking check my post here
I hope this helps until I post my video, or if you have specific questions let me know
Best,
Muhammed
Hey Muhammed, happy new year to you too!
I am really looking forward to it, as I am trying to push ACES into our workflow but obiously I want to understand everything as best as possible before trying to explain it to others.
Will look into your post now, thank you very much.
Much appreciate it!
best regards,
Karol
Good luck!
I spent time on adapting my previous 2 studios to ACES, this topic touches on quality so it was worth the effort at the end, and I learned a lot from this experience. I know that both places are still using ACES until now which makes me happy
This is an older video on ACES in the frame buffer,
Which I will cover briefly in the new video as well
On another note, Color picking in Maya and the native color management are both great. Much better than 3Ds Max, as you have control over what you use, 3Ds Max actually doesn’t have any native color management.
Best,
Muhammed
Morning Karol,
This looks fine to me, I think your settings are correct. The ACES look has more contrast by nature, hence you see the difference
You will need to adjust your lights/exposure to be brighter
And there is a way of having a perfect match for a logo/texture if needs be, keep in mind that all the ACES transforms are reversable including the tonemapped version. I will touch on this in details in my video
And in the link above, I explained the part about matching a logo. Basically you need to load it with an IDT ACES sRGB in stead of the usually Utility sRGB Texture
Best,
Muhammed
If you use the AMPAS preset in the frame buffer make sure to change its gamma to 0.8 or so, to avoid some of the contrast.. like what I do in my video above
This AMPAS preset has more contrast than the ACES sRGB view
About Kelvin temperature, how do you set this up for your lights? }
V-Ray should do the conversion internally for it.. but generally speaking if something is not correct it will look very saturated than usual
Best,
Muhammed
Goodmorning Mohammed,
I’ve watched your video yesterday, very informative!
Regarding the light, what I meant is that temperature values are much more sensitive, especially warm values such as 3500 are very very saturated / warm.
This multiplies much more if you place a light close to for example gold / brass surface.
Yup, I understand. How do you set your kelvin temperature value for the light?
There are multiple ways this could be done. I will double check that our ACES conversions are correct for temperature
Best,
Muhammed
The differences are very subtle in this example, I know…
The way I see it:
@Muhammed_Hamed is this what you mean?
thank you.
so this sRGB rendered image is using Filmic Hable or something else for tone mapping?
also I wouldn’t worry about light intensity - adding 1 stop of exposure do ACEScg render so far works for me just fine (to match them close to sRGB).
If I remember correctly the sRGB only had some curves applied in VFB. No additional tonemapping. All the rest was done in PS.
Personally, I try to not rely much on exposure, as it always flattens the entire image in any case. I’d rather look too increase the scene lights seperately which in combination with ACES gives a nice depth boost.
I have to say I consider Filmic AMPAS tone mapper curve as essential in comparing sRGB to ACEScg. otherwise its just apples to oranges. I think every video I stumbled upon on YT is presenting raw sRGB renders with just gamma transform against ACEScg output nicely transformed to sRGB screen. this is quite misleading.
and changing exposure or adjusting light - same thing, just some noise if done in post.
