simplified UI - python
Oh, that’s interesting. I thought skysurfer was suggesting a preset button. I’ll look at both…
So here’s an update, I included a series of buttons for output size:
it has 5 presets for 4:3 aspect and 16:9 aspect, and custom input. when you enter a custom value, that value goes to the middle button, and the buttons to either side will change to give you smaller and larger options at the same aspect as the custom value.
It does make the interface bigger of course, if i ever figure out how to deal with exposure I’ll probably move it to a different toolbar button.
I also reorganized the text on the other sliders a little. i’m thinking of changing it to be static text “draft low medium high extreme” over the slider instead of dynamically changing, my students have found it confusing.
let me know what you think!
-emil
VfR Simple 1.04.zip (16.3 KB)
I’ve already downloaded your toolbar!
Thanks for sharing, it’s a very usefull tools and a great help for who want to try scripting Vray.
I hope your script could push Chaosgroup to add more script method and increase the number of custom script.
Nice to see that’s possible to change the resolution :wink:
Bye.
Riccardo
Joe B is already fixing these problems for the next vray release, hopefully that will happen soon too =)
let me know what you think. i’m planning on adding a checkbox to toggle the safe frame, and also changing the buttons so they don’t constantly change their value when you’re using custom input. lots to do.
for those who can’t download from the forums, this toolbar can also be downloaded here:
http://www.lookinglass.us/vray4rhinoWiki/tiki-index.php?page=V-Ray+Simplified+user+interface
Finally got around to fixing the custom input buttons, nothing else new, here’s v1.05:
Could I link your website from mine to let my users download the toolbar too?
PS: could be good idea to publish your work also in Food4Rhino.com, to let more people have this.
Thanks for sharing once more.
yes of course - i assume you can just do that but let me know if i need to assist.
also just updated this to include safe frame checkbox. default is on. auto updates when you change resolution.
thanks for letting me know about Food4Rhino - i’ll go check it out!
Ok I’ll share asap.
You did so great job that I stop doing mine :wink:
Thanks.
I’m glad its useful! But sorry it stopped you ;( yours was quite ambitious! hope to see more good stuff from you. Also send me your website, I’d like to check it out…
Since Joe fixed a lot of the previously not-working script functions in the nightly builds (thanks Joe!!!), I’ve updated the interface to work with them.
(Micha, I’m still working on buttons to save and load IRMap Cache files, but otherwise i think this is everything we had talked about including):
Take a look:
Certain functions will ONLY work with the nightlies. if you are NOT using the nightlies, this is what happens:
-Lens shift will do the math and show the result, but will not actually change the vray setting
-the entire “Exposure” panel doesn’t work. you may see options change, but they won’t change in the vray options
-detail enhancement checkbox doesn’t work. however, the value WILL change automatically as you change the IRMap slider and it will update in Vray, but if DE is turned off in the vray options my checkbox won’t turn it on and the values won’t be used.
The following will also automatically change when you launch the panel (again none of this works unless you are using the nightlies):
-Physical camera = on
-Vignetting = off
-Gamma Correction output (in color mapping panel) = 2.2
-Correct LDR Textures = on
-Correct RGB colors - on
I know these will probably make some of you unhappy. Again, my goal is to make vray easy for new users that i am teaching, and linear workflow is way too complex. I’m considering setting up a “set newbie defaults” button to do all the defaults, so that others can use the UI without getting their settings all screwed up. This thing is also getting really big, so i plan to break it up into smaller panels.
Anyway, take a look, let me know if you have suggestions!!
Great to see the tool growing. :slight_smile:
For me as advanced user it would be great if GI cache tool could be used independent from the VfR simple, since it automatic change some settings. Maybe you could extract the cache code to two button scripts - one for “reuse GI cache” and one for “disable GI cache”.
I agree - I’m not happy that all these defaults get automatically set every time, I’m thinking about just having a separate button to set the defaults. And I’ll definitely start breaking the panels out also. Maybe a section just for indirect illumination, another for render output and exposure, etc.
when you say GI cache, you mean IRMap right? What about LC? Or is there another cache for all GI?
For GI cache I mean caching IM and LC. It’s cumbersome to rerender image with this caches yet, a quick switch is missing. :wink:
Ok yes, that’s next for me to work on. The IRmap cache save function was fixed by Joe, ill have to look at LC.
minor update:
safe frame now works correctly even if the file rhino options start out set to “viewport resolution”
otherwise i’m very behind on my wishlist for this, but swamped, probably won’t do more until the holidays.
well it’s been a LONG time, but i’ve finally been able to get this tool 100% functional! thanks to the Chaosgroup USA team for giving access in the latest release 2.00.25962 to all the options i needed!
here’s what’s new:
- Warning message if you don’t want it to change your defaults
- Custom Render button linked to lens shift switch and warns if rendering non-perspective views
- Image sampler slider can finally detect settings
- faster starting
VfR Simple 2.10 download here:
next i’ll work on Micha’s suggestions above for saving caches, and also breaking this up into smaller dialogs so the whole thing doesn’t have to be on screen all the time.
Nice work! Great tool.
Thanks! I’m open to suggestions, I can do a lot more with the latest release.
the Render button did not work for me for some reason.
Really!? I’ll take another look.
