i need to simulate smoke being sucked / blown through a pipe system, mainly for a close up of three different forms of a 90° pipe bend. The first one has perfect air pathway with no turbulences at all, the second pipe bend creates some minor turbulences at the inner bending and the third one ( spiral hose ) has lots of turbulences at the inner wall.
The project has a tight budget, so i need to get this done in a reasonable timeframe. There is no need for a hyper realistic result, but the differences in the air pathways should be recognizable.
Is PhoenixFD capable of creating this ( have some minor experiences in it ) within a manageable timeframe ?
How would you setup a simulation like this ?
Before i buy a monthly subscription of Phoenix and give it a try, i`d like to know what`s the best workflow for this project. I also have a license for Tyflow, but Phoenix seems to be the better software for simulation and rendering this type of smoke simulation.
I’m just finishing up something to do with oil refinery processes, so needed to show indicative gases in pipes etc., so pretty similar
stuff to what you want I think.
I used Embergen and couldn’t have been happier with the result. It’s simple to set up, instant realtime feedback and great output, either rendered directly
or for whatever reason a cache to use elsewhere.
A bonus is a sub price that is ridiculously good value…20 quid rent to buy or just 1 month and then cancel sub.
thanks for your reply. This looks quite promising, so i definitely will give it a try.
Haven`t watched any tutorials so far, but would be interested about your workflow.
You do the smoke simulation and rendering of it in Embergen and then compose it in AE with the Vray rendering of the other 3d content ?
Best
Robin
Process is simple; export the geo, create emitters and tweak in realtime to get the desired effect.
Their renderer has a load of options to further customise the look and it renders quickly.
For the renders, yes I imported my cams for scene then comped everything in AE.
I had a few very different sims to try to get done quickly as proof of concept preview stuff, so I
got a demo to play around with and basically had it all done in a day or so, going from zero knowledge to comfortable with it in a matter of a few hours.
I simply could not have done that with Phoenix, as it’s overly complex and takes so tediously long to iterate/troubleshoot.
I did export the cache for one sim, as a test just to see how quick the renders would be, which was of course much slower.
Plus, for any reasonable quality, the cache is enormous, slow to write out/read in, unwieldy and just a pain to work with.
So ultimately, for what I wanted to achieve, Embergen just won in every area…no contest
i downloaded the trial version and played around today. Impressive and very fast simulations, thats for sure.
Unfortunately there seems to be some bugs, i.e. the FBX import isn`t working for me at all ( no objects visible and no camera import as well ).
Had also problems to create the necessary forces i need, to visualize the different turbulences at specific parts of the tube system.
Didn`t found a way to have forces impact only in specific local areas of the scene, instead they impact the whole scene…i.e. i used the spline force to suck the particles inside the horizontal part of the tube system, but then it pushes also particles on vertical tube parts at one side of it.
Collision distance was another think i could not fix and so on.
Anyway…might be some missing knowledge on my side for embergen, but i think i will give Phoenix a try as well.
But thanks for your reply on my request, there might be some usage for embergen in the future.
Best
Robin
So when using PhoenixFD…will i have options to add forces which only impacts specific small areas of the tube system ?
I need as much control over the flow as possible to further emphasize and visually highlight turbulence occurring at certain points in the pipe system. The whole thing doesn’t necessarily have to be physically correct, as mentioned in my initial post.
My experience with Phoenix is limited when it comes to specifics like those you mentioned, though probably the particle tuner can do certain things to help.
Generally with particle stuff I will try the ‘path of least resistance’ approach, so break down something tricky into sections where possible, then stitch.
There is less to set up/tweak and fewer opportunities for something which looks good when it begins to subsequently get messed up when you reach
another area.
It sounds like you could do this for your purposes, if, as you mentioned, it doesn’t need to be hyper-realistic (which will be a challenge regardless of software I think)
With the Embergen issues you found, I had none of those, though of course I had to suss out stuff and troubleshoot lack of immediate knowledge.
So for instance, you need to make sure the imported stuff is flagged as visible (can’t remember the default settings). Also make sure it’s the correct scale/xform etc.
Collision distance is workable I found, although you can overcome any shortfall with adjusted geometry to compensate.
In your situation I imagine one flow with sufficient overlap, another flow for weird turbulence, with falloff/overlap, then whatever else…all stitched together.
I don’t recall whether there’s a falloff directly in the e.g. vortex node, that would limit its influence and so allow for it to exist in the main sim, but it’s worth investigating maybe.
I’d love to have a look and let you know but I’m mid-render of my shots and it’s going to be 24/7 for the next month, so I’m in thumb-twiddling stage
Just to add to this in case it proves worthwhile, I asked on their Discord about isolating the different forces at bends and the reply was ‘‘You can use shape masks for different sections of the pipe to isolate the different forces’’.
