Which is two objects with the same triplanar mtl (set on local) applied, however you can notice pattern goes vertically on vertical part, and horizontally on the horizontal (exactly how I want it to go).
BUT, before doing a whole series of actions it looked like this:
And so now finally we have what we want. But this workflow is far from being efficient IMO.
I tried uvw box mapping as well, but that too depends on local axis so it’s basically the same problem. UNLESS you break the link(instance) between the two uvw maps (which I don’t want to do) and rotate them separately.
Anyone has any suggestions on this?
EDIT:
After doing these tests it looks to me that object’s “local” axis and “pivot point axis (or direction)” is two totally different things, or..? Because if it were the same, rotating object’s pivot point should change object’s local axis too, which in result should change the direction of triplanar mtl. But in this case rotating pivot point does nothing.
So I guess we should first start from clarifying what exactly IS local axis and how does it correlate (or does not) with pivot point axis.
I can only tell how to shorten your action list, but it’s not ideal solution either.
rotate horizontal beam vertically
reset its transforms
rotate it back to horizontal position
I don’t know if there’s better solution. Karba (FStorm) would probably add something like “align to longest axis” checkbox to a bitmap loader, but that wouldn’t work with cubical objects :]
Yeah I already heard something about that “align to longest axis” feature in fstorm, and it sounds awesome. And it would work like 99% of the time, since how many perfectly cubical objects do we have in arch viz (or even real life)?
In Corona now it’s a mess- you have to either create multiple copies of the same mtl just with different rotation settings in triplanar settings, or rotate object’s transforms the way I (or you) described.
EDIT:
And do you have any comments on this? My main question still remains on what EXACTLY is local (axis/space?) ? If it’s not the same as pivot point axis. And after these tests it’s obvious that it isn’t the same thing. Is there any way to “view” what local axis looks like? What’s the direction of it?
Well, discrepancy between object’s pivot point and its local transforms, is a mystery for me too. I guess that question should be asked in Autodesk community, maybe someone there knows the answer?
Wait, what? Is this already implemented in Fstorm? o_O
I believe I’ve read a comment in Fstorm’s group (dunno if it was from Andrey himfself or someone else) about implementing (or planning to implement) this feature into Fstorm.
BUT might be as well it was a dream of mine, not 100% sure now
Create a reference cube with the correct mapping you want, convert it to editable poly > attach the other object that has the incorrect mapping, it should now assume the correct mapping then just delete the cube.
or
if you use autoGrid when creating your objects, it will assume the local cooridnates based on whatever surface you are generating it on.
or
Rotate your vertices in vertex sub object mode, then rotate it back in position object selection mode. You could create a script to make this instantaneous.
Create all objects on the same plane/axis (for example front view)
So 6 in total (and I guess there’s more) but none of them seems to be hassle-free. + Pretty much all of them has some kind of disadvantages.
But it looks like there’s no other/magical way.
