Hi, I am rendering a sequenz on two machines in Single Frame mode.
But one PC renders the frames slightly different to the other.
It looks a bit more sharp.
I used the normal backburner netrenderer. Started Mangager and Server one the authorized Vray PC and just the Server on the other one.
Is that all to do normal networkrendering? No DR or anything…
Hope to get help soon, movie must be rendered till Wednesday.
Yes, rendering with GI. But ehrn I render just on one PC, there is no flickering. And in single frame the irradiance map is new computed at every frame, there should not be a difference with the two PC´s, or not?
mmm every test I’ve done with single map imap has some sort of flickering in the GI (read i use as low as possible hsubdivs)…if i understand it correctly this will diminish the higher you push the hsubdivs, along with pushing render times higher.
I have completed a number of animations using the nth frame method rendered on a network with varying processor types and no variation in the resulting frames.
double check you have exactly the same vray installs, ie libmmd.dll etc (i know you said you have but stranger things have happened)
is there any reason why you chose not to use the nth method? moving objects?
I got moving objects and an animated light, so single frame seems to be the only solution. And as I wrote, one PC rendering the frames is alright, but not both. You can see clearly which PC rendered which frame.
And there are both amd´s. Only difference is that on one is XP, one the other one WIn2000, but this should not make a differnece?
Double checked all the installed vray files and other PlugIns
we had a modeler here change the units, and all the renders came out different.
try replacing the 3dsmax.ini in the root folder
if there is a scale issue, this will fix it.
OK, now I got the next problem, it even starts to flicker when I render just on one PC. But exact in the same scene, whith the same settings which rendered alright before.
I put up the movie, that shows all the problems.
In the beginning it was just one PC rendering, and it looks good enough.
Then it starts flickering, that´s when the other PC in the network joined.
After the cut it is just one PC again, the one which rendered alright in the beginning.
Settings for all renderings were:
AA- Simple two level
High Animation, no secondary bounces
Single Frame
the rest is left to default.
One HDRI, one Direct light
Please Help, movie must be finished on Wednesday, and right now I can´t render anything proper at all.
I´m pritty sure I tried this, I tried about anything the last days. This is my first VRay Animation. Unfortunately experimenting with GI animations is very slow thing to do…
And as you see it worked for about 2 seconds, and the warnings came there as well.
Hope a chaotic member is having a look at this soon. Maybe the bug is just me.
I agree with Moose looks like the hdri environment giving you problems, I like to use the splutter fish loader in the environment allowing me to blur the hdri , a blurred hdri will get rid of the noise.
If that doesn’t help I would render the ground as a separate pass with a saved solution and comp in the ball and the character rendered with single frame. By setting the correct matte properties on the ground you should get correct shadows and GI.
Nice clips I know you are probably frantic to ge this fixed. I can’t really help, it looks strange to me too. As a suggestion though… you can probably use multiframe for the camera rotation clip.
Would you mind telling us which HDRI file that is you are using?
Have you checked wether the QMC-Settings are the same on both machines (should be if you use the same file on both machines)
I remember someone reported problems with flickering renders and HDR-Images because Max´s way of image filtering and HDRI´s are not compatible and the maps filtering was not turned off in the material editor. I´m not sure if I remember that correctly nor if this is still true for the current max version (5.1.1) or vray build though.
